查看: 1851|回复: 5
Skyline插件配置
176
240
8384
8384
发表于 2019-3-20 21:44:00 | 显示全部楼层 |阅读模式
1、自己开发了个exe的小工具,放到Skyline的软件里,修改地址,安装目录/Lang/1033/Lang.xml改为如下。TE7版本。 QQ截图20190320214034.png
<?xml version='1.0' encoding='utf-8'?>
<Lang>
  <Category id="CategoryNavigation" caption="Test">
    <Panel id="PanelNavigateto" caption="tttt" />
  </Category>
        <Groups>
    <Group name="Tools">
      <Item caption="Collaboration" id="StartCollaboration" Path="Collaboration\Collaboration.html" NeedProject="0">
        <!-- The ID should be the relative path from the Tools folder -->
        <Ribbon Show="1">
          <Category id="CategoryTools" caption="" />
          <!-- caption is optional. use it only in case of new category -->
          <Panel id="PanelCollaboration" caption="Collaboration" />
          <!-- caption is optional. use it only in case of new panel -->
          <ToolTip title="Collaboration" description="Connect TerraExplorer users on one collaborative network."/>
          <Icon path="Collaboration.ico"/>
        </Ribbon>
        <Container>
          <Panel />
        </Container>
        <file name="SessionManager.dll">
          <!-- <comClass clsid="{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}" iid="{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}" event_iid="{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}" tlbid="{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}"></comClass> -->
          <comClass clsid="{69E1509B-58CA-40F5-8A1A-C8D041F04649}" iid="{84240F19-6A9A-4B66-828B-D3EE0F025FDF}" tlbid="{4D350B23-D6D1-46C0-BC2A-5E7EC3D9C34E}"/>
        </file>
      </Item>
            <Item caption="管道工具" id="OilPipe" Path="Pipe\OilPipe.exe" NeedProject="0">
                                <Ribbon Show="1">
                                        <Panel id="PanelOilPipe" caption="插件组" />
                                        <ToolTip title="自定义工具工具" description="自定义管道参数."/>
                                </Ribbon>
                                         <Container>
                                        <Panel />
                                </Container>
                                </file>
                        </Item>
    </Group>
        </Groups>
        <LangCaption English="English" InLang="English"/>
</Lang>
Lang.rar (919 Bytes, 下载次数: 6)
2
8
262
中级会员
Rank: 3Rank: 3
262
发表于 2019-3-28 11:07:47 | 显示全部楼层
这个怎么用啊
2
8
262
中级会员
Rank: 3Rank: 3
262
发表于 2019-3-28 11:08:57 | 显示全部楼层
一直提示选中shap文件
176
240
8384
8384
 楼主| 发表于 2019-3-28 21:01:27 | 显示全部楼层
zxkeb7 发表于 2019-3-28 11:08
一直提示选中shap文件
是的,选中shape线,然后就会根据这个线生成管道了。这个不是专门生成管道的,是用来控制每个段距离,和加上一个焊接口的。
176
240
8384
8384
 楼主| 发表于 2019-3-28 21:02:21 | 显示全部楼层
选中一个shp线文件,然后设置每个段长度,点击生成。如果shp线很多或者很长,建议设置长一点每个段
2
8
262
中级会员
Rank: 3Rank: 3
262
发表于 2019-4-3 15:44:30 | 显示全部楼层
好的~
GMT+8, 2019-8-26 12:30 , Processed in 0.185140 second(s), 33 queries .
